Documentation for Users
2.1.2
Perception Toolbox for Virtual Reality (PTVR) Manual
When you create a Text visual object, you can make one of the two following parameters active to define the size of the characters of this Text object (See the definitions of these two parameters here):
fontsize_in_postscript_points visual_angle_of_centered_x_height_degThe argument (20 and 0) passed by default to these parameters are shown below:
my_text = PTVR.Stimuli.Objects.Text ( ..., fontsize_in_postscript_points = 20, visual_angle_of_centered_x_height_deg = 0, ... )
If you pass an argument (different from zero) to the parameter visual_angle_of_centered_x_height_deg, the parameter fontsize_in_postscript_points will be ignored.
Defining the parameter visual_angle_of_centered_x_height_deg is very convenient to define an angular x-height for your text.
For the definition of x-height (a very important and common unit in the psychophysics of reading), please see:
However, this nominal angular size will only correspond to the actual value if you respect some conditions that are explained in details here.
To say it quicky: your text should be positioned on a Tangent Screen and at the center of this tangent screen (i.e. at the point called Screen Origin - SO in the figures here).
Then, and only then, the angle (in degrees) subtended by the height of an 'x' (for a given font) at the origin of the current Coordinate System will correspond to the value of visual_angle_of_centered_x_height_deg .
It is often convenient to use the visual_angle_of_centered_x_height_deg parameter, even when you do not want to control precisely the actual angular value of the text.
The simplest example is when you want to display labels for objects placed at short and long viewing distances: you want these labels to be visible independently of their viewing distance and using the visual_angle_of_centered_x_height_deg parameter is THE solution.
A good example is shown in the 1_global_cartesian_coordinate_system.py demo where the axes tick labels are all visible although they are placed at very different viewing distances (path of this demo: ...\PTVR_Researchers\Python_Scripts\Demos\Coordinate_Systems).
my_text = PTVR.Stimuli.Objects.Text ( text = 'Hello World !',
position_in_current_CS = np.array ( [ 0, 1, 1 ] ),
fontsize_in_postscript_points = 60
The path of demos is: ...\PTVR_Researchers\Python_Scripts\Demos\Text
| Python file | Description |
| 10_hello_world.py | Simplest way of displaying text (character size is defined with fontsize_in_postscript_points, i.e. this is NOT an angular value) |
| text_height_at_different_radial_distances.py | Visually check that texts of same angular x-height at different viewing distances are visually overlapping. |
| Stroop_effect_with_tangent_screens.py | A simple demo of the Stroop effect with simultaneously displayed tangent screens. (character size is defined with fontsize_in_postscript_points, i.e. this is NOT an angular value - why is it here then? just for the pleasure of seeing colours)
